[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.in.poly/poly2rast.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Jun 14 04:51:07 EDT 2007
Hello hamish,
ANALYSIS
raster/r.in.poly/poly2rast.c functions
poly_to_rast (Begins at: 7 Ends at: 88)
Complexity: | 13 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 27 | | OK |
LOC: | 82 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
