[GRASS-QA] GRASS QA: hamish | ./grass6/lib/display/draw2.c |11 clones ( draw2.c )| 0 monsters | 1 warnings
Thu Jun 14 06:42:23 EDT 2007
Hello hamish,
ANALYSIS
lib/display/draw2.c functions
alloc_int (Begins at: 79 Ends at: 88)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
alloc_float (Begins at: 90 Ends at: 99)
LOC:          |      10 |       |      OK |
metrics are OK
dealloc_float (Begins at: 101 Ends at: 116)
ParamNBR:     |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
do_convert (Begins at: 118 Ends at: 129)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
dist_plane (Begins at: 131 Ends at: 134)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
interpolate (Begins at: 136 Ends at: 139)
ParamNBR:     |       4 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
clip_plane (Begins at: 141 Ends at: 173)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
do_clip (Begins at: 175 Ends at: 198)
Complexity:   |       9 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
shift_count (Begins at: 200 Ends at: 203)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
shift_angle (Begins at: 205 Ends at: 208)
LOC:          |       4 |       |      OK |
metrics are OK
coerce (Begins at: 210 Ends at: 216)
LOC:          |       7 |       |      OK |
metrics are OK
euclidify (Begins at: 218 Ends at: 248)
Complexity:   |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
do_ll_wrap (Begins at: 250 Ends at: 281)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      32 |       |      OK |
at least 1 values are close to an outlier please consider revising code
D_set_clip (Begins at: 283 Ends at: 311)
LOC:          |      29 |       |      OK |
metrics are OK
D_set_clip_margin (Begins at: 313 Ends at: 326)
LOC:          |      14 |       |      OK |
metrics are OK
D_clip_to_map (Begins at: 328 Ends at: 347)
LOC:          |      20 |       |      OK |
metrics are OK
D_move_clip (Begins at: 349 Ends at: 368)
LOC:          |      20 |       |      OK |
metrics are OK
line_clip (Begins at: 370 Ends at: 395)
CalledNBR:    |      11 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
line_clip_ll (Begins at: 397 Ends at: 419)
LOC:          |      23 |       |      OK |
metrics are OK
D_cont_clip (Begins at: 421 Ends at: 437)
LOC:          |      17 |       |      OK |
metrics are OK
D_polydots_clip (Begins at: 439 Ends at: 470)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
cull_polyline_plane (Begins at: 472 Ends at: 517)
LOC:          |      46 |       |      OK |
metrics are OK
polyline_cull (Begins at: 519 Ends at: 546)
LOC:          |      28 |       |      OK |
metrics are OK
D_polyline_cull (Begins at: 548 Ends at: 560)
LOC:          |      13 |       |      OK |
metrics are OK
polyline_clip (Begins at: 562 Ends at: 568)
LOC:          |       7 |       |      OK |
metrics are OK
D_polyline_clip (Begins at: 570 Ends at: 582)
LOC:          |      13 |       |      OK |
metrics are OK
cull_polygon_plane (Begins at: 584 Ends at: 629)
LOC:          |      46 |       |      OK |
metrics are OK
polygon_cull (Begins at: 631 Ends at: 658)
LOC:          |      28 |       |      OK |
metrics are OK
D_polygon_cull (Begins at: 660 Ends at: 669)
LOC:          |      10 |       |      OK |
metrics are OK
clip_polygon_plane (Begins at: 671 Ends at: 711)
LOC:          |      41 |       |      OK |
metrics are OK
polygon_clip (Begins at: 713 Ends at: 740)
LOC:          |      28 |       |      OK |
metrics are OK
D_polygon_clip (Begins at: 742 Ends at: 751)
LOC:          |      10 |       |      OK |
metrics are OK
box_clip (Begins at: 753 Ends at: 769)
CalledNBR:    |       9 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
box_clip_ll (Begins at: 771 Ends at: 784)
LOC:          |      14 |       |      OK |
metrics are OK
D_box_clip (Begins at: 786 Ends at: 795)
LOC:          |      10 |       |      OK |
metrics are OK
D_move (Begins at: 797 Ends at: 803)
LOC:          |       7 |       |      OK |
metrics are OK
D_cont (Begins at: 805 Ends at: 811)
LOC:          |       7 |       |      OK |
metrics are OK
D_polydots (Begins at: 813 Ends at: 817)
LOC:          |       5 |       |      OK |
metrics are OK
D_polyline (Begins at: 819 Ends at: 823)
LOC:          |       5 |       |      OK |
metrics are OK
D_polygon (Begins at: 825 Ends at: 829)
LOC:          |       5 |       |      OK |
metrics are OK
D_box (Begins at: 831 Ends at: 843)
LOC:          |      13 |       |      OK |
metrics are OK
D_line_width (Begins at: 845 Ends at: 863)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
This file has 11 potentially cloned functions:
  D_polyline_clip  D_polyline_cull  cull_polygon_plane  cull_polyline_plane  polygon_clip  polygon_cull  polyline_cull  D_polygon_clip  D_polygon_cull  D_cont  D_move
In lib/display/draw2.c clones of  D_polyline_cull are:
	lib/display/draw2.c  D_polyline_clip
In lib/display/draw2.c clones of  D_polyline_clip are:
	lib/display/draw2.c  D_polyline_cull
In lib/display/draw2.c clones of  D_move are:
	lib/display/draw2.c  D_cont
In lib/display/draw2.c clones of  D_cont are:
	lib/display/draw2.c  D_move
In lib/display/draw2.c clones of  polygon_cull are:
	lib/display/draw2.c  polygon_clip
	lib/display/draw2.c  polyline_cull
In lib/display/draw2.c clones of  D_polygon_clip are:
	lib/display/draw2.c  D_polygon_cull
In lib/display/draw2.c clones of  cull_polygon_plane are:
	lib/display/draw2.c  cull_polyline_plane
In lib/display/draw2.c clones of  cull_polyline_plane are:
	lib/display/draw2.c  cull_polygon_plane
In lib/display/draw2.c clones of  D_polygon_cull are:
	lib/display/draw2.c  D_polygon_clip
In lib/display/draw2.c clones of  polygon_clip are:
	lib/display/draw2.c  polygon_cull
In lib/display/draw2.c clones of  polyline_cull are:
Threshold GRASS6 key metrics values at 2007-06-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
