[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.category/main.c |no clones | 3 monsters | 0 warnings
Fri Jun 22 05:50:30 EDT 2007
Hello martinl,
ANALYSIS
vector/v.category/main.c functions
main (Begins at: 48 Ends at: 468)
Complexity:   |      75 |   *** | MONSTER |
CalledNBR:    |      97 |   *** | MONSTER |
LOC:          |     421 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
