[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_base/table.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jun 27 12:37:45 EDT 2007
Hello markus,
ANALYSIS
lib/db/dbmi_base/table.c functions
db_alloc_table (Begins at: 12 Ends at: 35)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 24 | | OK |
metrics are OK
db_init_table (Begins at: 44 Ends at: 50)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 7 | | OK |
metrics are OK
db_free_table (Begins at: 59 Ends at: 70)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
db_set_table_name (Begins at: 79 Ends at: 83)
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
db_get_table_name (Begins at: 92 Ends at: 96)
LOC: | 5 | | OK |
metrics are OK
db_set_table_description (Begins at: 105 Ends at: 109)
LOC: | 5 | | OK |
metrics are OK
db_get_table_description (Begins at: 118 Ends at: 122)
LOC: | 5 | | OK |
metrics are OK
db_get_table_number_of_columns (Begins at: 131 Ends at: 135)
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
db_get_table_number_of_rows (Begins at: 144 Ends at: 159)
CalledNBR: | 6 | | OK |
LOC: | 16 | | OK |
metrics are OK
set_all_column_privs (Begins at: 168 Ends at: 180)
LOC: | 13 | | OK |
metrics are OK
get_all_column_privs (Begins at: 189 Ends at: 204)
LOC: | 16 | | OK |
metrics are OK
db_set_table_select_priv_granted (Begins at: 213 Ends at: 217)
LOC: | 5 | | OK |
metrics are OK
db_set_table_select_priv_not_granted (Begins at: 226 Ends at: 230)
LOC: | 5 | | OK |
metrics are OK
db_get_table_select_priv (Begins at: 239 Ends at: 243)
LOC: | 5 | | OK |
metrics are OK
db_set_table_update_priv_granted (Begins at: 252 Ends at: 256)
LOC: | 5 | | OK |
metrics are OK
db_set_table_update_priv_not_granted (Begins at: 265 Ends at: 269)
LOC: | 5 | | OK |
metrics are OK
db_get_table_update_priv (Begins at: 278 Ends at: 282)
LOC: | 5 | | OK |
metrics are OK
db_set_table_insert_priv_granted (Begins at: 291 Ends at: 295)
LOC: | 5 | | OK |
metrics are OK
db_set_table_insert_priv_not_granted (Begins at: 304 Ends at: 308)
LOC: | 5 | | OK |
metrics are OK
db_get_table_insert_priv (Begins at: 317 Ends at: 321)
LOC: | 5 | | OK |
metrics are OK
db_set_table_delete_priv_granted (Begins at: 330 Ends at: 334)
LOC: | 5 | | OK |
metrics are OK
db_set_table_delete_priv_not_granted (Begins at: 343 Ends at: 347)
LOC: | 5 | | OK |
metrics are OK
db_get_table_delete_priv (Begins at: 356 Ends at: 360)
LOC: | 5 | | OK |
metrics are OK
db_table_to_sql (Begins at: 368 Ends at: 438)
Complexity: | 16 | * | |
CalledNBR: | 28 | | OK |
LOC: | 71 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
