[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/dbmi_client/table.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Jun 27 12:57:07 EDT 2007
Hello markus,
ANALYSIS
lib/db/dbmi_client/table.c functions
db_table_exists (Begins at: 16 Ends at: 74)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 59 | | OK |
metrics are OK
db_get_table_number_of_rows (Begins at: 83 Ends at: 98)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 16 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-06-27 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
