[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.class/signature.c |1
	clones ( curses.c graphics.c mouse.c signature.c )| 0
	monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Mar  1 19:38:15 EST 2007
Hello brad,
ANALYSIS
imagery/i.class/signature.c functions
init_sig_routines (Begins at: 39 Ends at: 58)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
prepare_signature (Begins at: 65 Ends at: 159)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      95 |       |      OK |
metrics are OK
show_signature (Begins at: 176 Ends at: 251)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
done (Begins at: 253 Ends at: 256)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
display_signature (Begins at: 261 Ends at: 321)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
have_signature (Begins at: 329 Ends at: 332)
LOC:          |       4 |       |      OK |
metrics are OK
save_signature (Begins at: 340 Ends at: 357)
CalledNBR:    |       2 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
yes_save (Begins at: 359 Ends at: 386)
CalledNBR:    |       6 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
dont_save (Begins at: 389 Ends at: 392)
LOC:          |       4 |       |      OK |
metrics are OK
write_signatures (Begins at: 399 Ends at: 408)
CalledNBR:    |       5 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  write_signatures
In imagery/i.class/signature.c clones of  write_signatures are:
	display/d.rast.edit/edit.c  use_mouse
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
