[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.rast.edit/menu.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:17 EST 2007
Hello glynn,
ANALYSIS
display/d.rast.edit/menu.c functions
main_menu (Begins at: 21 Ends at: 143)
Complexity: | 19 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 47 | * | |
LOC: | 123 | * | |
metrics are OK
option_menu (Begins at: 146 Ends at: 190)
Complexity: | 5 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 45 | | OK |
metrics are OK
color_menu (Begins at: 194 Ends at: 279)
Complexity: | 13 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 86 | | OK |
metrics are OK
map_type_menu (Begins at: 283 Ends at: 330)
Complexity: | 7 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 48 | | OK |
metrics are OK
arrow_options (Begins at: 333 Ends at: 371)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
get_arrow_inputs (Begins at: 375 Ends at: 434)
Complexity: | 9 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 60 | | OK |
metrics are OK
arrow_map (Begins at: 438 Ends at: 486)
Complexity: | 6 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 49 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
