[GRASS-QA] GRASS QA: glynn |
./grass6/display/drivers/XDRIVER/Serve_Xevent.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:19 EST 2007
Hello glynn,
ANALYSIS
display/drivers/XDRIVER/Serve_Xevent.c functions
get_xevent (Begins at: 27 Ends at: 58)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 32 | | OK |
metrics are OK
service_xevent (Begins at: 60 Ends at: 102)
Complexity: | 8 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 43 | | OK |
metrics are OK
_time_stamp (Begins at: 104 Ends at: 109)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
check_redraw_process (Begins at: 111 Ends at: 138)
Complexity: | 5 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 28 | | OK |
metrics are OK
list_push (Begins at: 140 Ends at: 146)
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
list_copy (Begins at: 148 Ends at: 154)
Complexity: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
list_free (Begins at: 156 Ends at: 164)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
spawn_redraw_process (Begins at: 166 Ends at: 236)
CalledNBR: | 23 | | OK |
LOC: | 71 | | OK |
metrics are OK
handle_resize_event (Begins at: 238 Ends at: 302)
CalledNBR: | 25 | | OK |
LOC: | 65 | | OK |
metrics are OK
check_flush (Begins at: 304 Ends at: 328)
Complexity: | 4 | | OK |
LOC: | 25 | | OK |
metrics are OK
set_title_busy (Begins at: 330 Ends at: 366)
CalledNBR: | 11 | | OK |
LOC: | 37 | | OK |
metrics are OK
set_busy (Begins at: 368 Ends at: 378)
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
