[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.profile/PlotProfile.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:17 EST 2007
Hello glynn,
ANALYSIS
display/d.profile/PlotProfile.c functions
PlotProfile (Begins at: 45 Ends at: 150)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      34 |       |      OK |
LOC:          |     106 |       |      OK |
metrics are OK
_get_cat (Begins at: 153 Ends at: 175)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
