[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/raster2.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:22 EST 2007
Hello glynn,
ANALYSIS
lib/display/raster2.c functions
D_set_overlay_mode (Begins at: 95 Ends at: 120)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
D_set_colors (Begins at: 122 Ends at: 266)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |     145 |     * |         |
metrics are OK
D_reset_color (Begins at: 268 Ends at: 284)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
D_color (Begins at: 286 Ends at: 293)
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
D_c_color (Begins at: 296 Ends at: 320)
CalledNBR:    |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
D_d_color (Begins at: 322 Ends at: 346)
LOC:          |      25 |       |      OK |
metrics are OK
D_f_color (Begins at: 348 Ends at: 376)
LOC:          |      29 |       |      OK |
metrics are OK
D_color_of_type (Begins at: 378 Ends at: 390)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
D_lookup_colors (Begins at: 392 Ends at: 412)
LOC:          |      21 |       |      OK |
metrics are OK
D_lookup_c_raster_colors (Begins at: 414 Ends at: 437)
LOC:          |      24 |       |      OK |
metrics are OK
D_lookup_f_raster_colors (Begins at: 439 Ends at: 463)
LOC:          |      25 |       |      OK |
metrics are OK
D_lookup_d_raster_colors (Begins at: 465 Ends at: 493)
LOC:          |      29 |       |      OK |
metrics are OK
D_lookup_raster_colors (Begins at: 495 Ends at: 562)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
D_raster_of_type (Begins at: 564 Ends at: 601)
Complexity:   |       2 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
D_raster (Begins at: 603 Ends at: 608)
LOC:          |       6 |       |      OK |
metrics are OK
D_c_raster (Begins at: 610 Ends at: 633)
LOC:          |      24 |       |      OK |
metrics are OK
D_f_raster (Begins at: 635 Ends at: 664)
Complexity:   |       3 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
D_d_raster (Begins at: 666 Ends at: 719)
LOC:          |      54 |       |      OK |
metrics are OK
D_check_colormap_size (Begins at: 721 Ends at: 739)
LOC:          |      19 |       |      OK |
metrics are OK
synch (Begins at: 741 Ends at: 746)
ParamNBR:     |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
allocate_colors (Begins at: 748 Ends at: 757)
CalledNBR:    |       4 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
is_grey_scale (Begins at: 759 Ends at: 809)
LOC:          |      51 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
