[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.class/input_std.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:15 EST 2007
Hello brad,
ANALYSIS
imagery/i.class/input_std.c functions
input_std (Begins at: 10 Ends at: 42)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
other (Begins at: 47 Ends at: 65)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
nstd050 (Begins at: 68 Ends at: 72)
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
nstd075 (Begins at: 75 Ends at: 79)
LOC:          |       5 |       |      OK |
metrics are OK
nstd100 (Begins at: 82 Ends at: 86)
LOC:          |       5 |       |      OK |
metrics are OK
nstd125 (Begins at: 89 Ends at: 93)
LOC:          |       5 |       |      OK |
metrics are OK
nstd150 (Begins at: 96 Ends at: 100)
LOC:          |       5 |       |      OK |
metrics are OK
nstd175 (Begins at: 103 Ends at: 107)
LOC:          |       5 |       |      OK |
metrics are OK
nstd200 (Begins at: 110 Ends at: 114)
LOC:          |       5 |       |      OK |
metrics are OK
nstd225 (Begins at: 117 Ends at: 121)
LOC:          |       5 |       |      OK |
metrics are OK
nstd250 (Begins at: 124 Ends at: 128)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
