[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Get_location.c |2
clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
raster_rgb.c raster_rgb.c Get_location.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:23 EST 2007
Hello glynn,
ANALYSIS
lib/driver/Get_location.c functions
COM_Get_location_with_pointer (Begins at: 4 Ends at: 16)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
COM_Get_location_with_line (Begins at: 18 Ends at: 30)
ParamNBR: | 6 | * | |
LOC: | 13 | | OK |
metrics are OK
COM_Get_location_with_box (Begins at: 32 Ends at: 44)
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
COM_Get_location_with_box COM_Get_location_with_line
In lib/driver/Get_location.c clones of COM_Get_location_with_line are:
lib/driver/Get_location.c COM_Get_location_with_box
In lib/driver/Get_location.c clones of COM_Get_location_with_box are:
lib/driver/Get_location.c COM_Get_location_with_line
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
