[GRASS-QA] GRASS QA: glynn | ./grass6/lib/D/Dcell.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:22 EST 2007
Hello glynn,
ANALYSIS
lib/D/Dcell.c functions
Dcell (Begins at: 25 Ends at: 73)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
cell_draw (Begins at: 76 Ends at: 113)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
