[GRASS-QA] GRASS QA: markus | ./grass6/lib/db/sqlp/print.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:32 EST 2007
Hello markus,
ANALYSIS
lib/db/sqlp/print.c functions
print_node (Begins at: 24 Ends at: 58)
Complexity: | 10 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 35 | | OK |
metrics are OK
sqpPrintStmt (Begins at: 60 Ends at: 174)
Complexity: | 27 | ** | Warning |
ParamNBR: | 1 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 115 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
