[GRASS-QA] GRASS QA: hamish | ./grass6/general/g.setproj/main.c |no clones | 3 monsters | 0 warnings
Thu Mar 1 19:38:30 EST 2007
Hello hamish,
ANALYSIS
general/g.setproj/main.c functions
main (Begins at: 49 Ends at: 632)
Complexity:   |     103 |   *** | MONSTER |
CalledNBR:    |     247 |   *** | MONSTER |
LOC:          |     584 |   *** | MONSTER |
3 metric are OUT OF RANGE!
min1 (Begins at: 634 Ends at: 640)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
leave (Begins at: 642 Ends at: 645)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
