[GRASS-QA] GRASS QA: glynn | ./grass6/lib/form/form.c |no clones |
1 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:24 EST 2007
Hello glynn,
ANALYSIS
lib/form/form.c functions
close_form (Begins at: 38 Ends at: 43)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
reset_values (Begins at: 47 Ends at: 56)
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
set_value (Begins at: 59 Ends at: 82)
Complexity: | 6 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 24 | | OK |
metrics are OK
submit (Begins at: 86 Ends at: 251)
Complexity: | 17 | * | |
CalledNBR: | 90 | *** | MONSTER |
LOC: | 166 | * | |
1 metric are OUT OF RANGE!
main (Begins at: 257 Ends at: 392)
Complexity: | 15 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 72 | ** | Warning |
LOC: | 136 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
