[GRASS-QA] GRASS QA: martinl | ./grass6/lib/db/dbmi_client/select.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:34 EST 2007
Hello martinl,
ANALYSIS
lib/db/dbmi_client/select.c functions
cmp (Begins at: 6 Ends at: 14)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
cmpcat (Begins at: 16 Ends at: 24)
LOC: | 9 | | OK |
metrics are OK
cmpcatkey (Begins at: 26 Ends at: 46)
LOC: | 21 | | OK |
metrics are OK
db_select_int (Begins at: 48 Ends at: 136)
Complexity: | 12 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 23 | | OK |
LOC: | 89 | | OK |
metrics are OK
db_select_value (Begins at: 138 Ends at: 190)
Complexity: | 6 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 11 | | OK |
LOC: | 53 | | OK |
metrics are OK
db_select_CatValArray (Begins at: 192 Ends at: 303)
Complexity: | 16 | * | |
CalledNBR: | 41 | * | |
LOC: | 112 | | OK |
metrics are OK
db_CatValArray_sort (Begins at: 307 Ends at: 310)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
db_CatValArray_get_value (Begins at: 316 Ends at: 326)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
db_CatValArray_get_value_int (Begins at: 332 Ends at: 342)
LOC: | 11 | | OK |
metrics are OK
db_CatValArray_get_value_double (Begins at: 348 Ends at: 360)
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
