[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/level_two.c
|2 clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
raster_rgb.c raster_rgb.c Get_location.c com_proto.c
com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c
i_face.c main.c main.c level_two.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:32 EST 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/level_two.c functions
Vect_get_num_nodes (Begins at: 31 Ends at: 34)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
Vect_get_num_primitives (Begins at: 43 Ends at: 55)
Complexity: | 7 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
Vect_get_num_lines (Begins at: 64 Ends at: 67)
LOC: | 4 | | OK |
metrics are OK
Vect_get_num_areas (Begins at: 76 Ends at: 86)
LOC: | 11 | | OK |
metrics are OK
Vect_get_num_faces (Begins at: 89 Ends at: 92)
LOC: | 4 | | OK |
metrics are OK
Vect_get_num_islands (Begins at: 101 Ends at: 104)
LOC: | 4 | | OK |
metrics are OK
Vect_get_num_dblinks (Begins at: 113 Ends at: 116)
LOC: | 4 | | OK |
metrics are OK
Vect_get_num_updated_lines (Begins at: 125 Ends at: 128)
LOC: | 4 | | OK |
metrics are OK
Vect_get_updated_line (Begins at: 137 Ends at: 140)
LOC: | 4 | | OK |
metrics are OK
Vect_get_num_updated_nodes (Begins at: 149 Ends at: 152)
LOC: | 4 | | OK |
metrics are OK
Vect_get_updated_node (Begins at: 161 Ends at: 164)
LOC: | 4 | | OK |
metrics are OK
Vect_get_node_coor (Begins at: 173 Ends at: 185)
Complexity: | 2 | | OK |
ParamNBR: | 5 | * | |
LOC: | 13 | | OK |
metrics are OK
Vect_get_line_nodes (Begins at: 194 Ends at: 207)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 14 | | OK |
metrics are OK
Vect_get_line_areas (Begins at: 216 Ends at: 229)
LOC: | 14 | | OK |
metrics are OK
Vect_get_node_n_lines (Begins at: 238 Ends at: 254)
LOC: | 17 | | OK |
metrics are OK
Vect_get_node_line (Begins at: 257 Ends at: 271)
ParamNBR: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
Vect_get_node_line_angle (Begins at: 274 Ends at: 280)
LOC: | 7 | | OK |
metrics are OK
Vect_get_centroid_area (Begins at: 289 Ends at: 295)
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
Vect_get_line_areas Vect_get_line_nodes
In lib/vector/Vlib/level_two.c clones of Vect_get_line_nodes are:
lib/vector/Vlib/level_two.c Vect_get_line_areas
In lib/vector/Vlib/level_two.c clones of Vect_get_line_areas are:
lib/vector/Vlib/level_two.c Vect_get_line_nodes
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
