[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.profile/read_rast.c |no clones | 0 monsters | 1 warnings
Thu Mar 1 19:38:31 EST 2007
Hello hamish,
ANALYSIS
raster/r.profile/read_rast.c functions
read_rast (Begins at: 15 Ends at: 103)
Complexity:   |      17 |     * |         |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      35 |       |      OK |
LOC:          |      89 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
