[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.colors/interact.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:16 EST 2007
Hello glynn,
ANALYSIS
display/d.colors/interact.c functions
interact (Begins at: 20 Ends at: 273)
Complexity: | 62 | *** | MONSTER |
ParamNBR: | 4 | | OK |
CalledNBR: | 70 | ** | Warning |
LOC: | 254 | ** | Warning |
1 metric are OUT OF RANGE!
shift_color (Begins at: 276 Ends at: 282)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
yes (Begins at: 284 Ends at: 309)
Complexity: | 7 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 26 | | OK |
metrics are OK
save_colors (Begins at: 311 Ends at: 326)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
