[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/zoom.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:29 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/zoom.c functions
zoom_window (Begins at: 12 Ends at: 82)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 71 | | OK |
metrics are OK
zoom_centre (Begins at: 85 Ends at: 122)
Complexity: | 1 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 38 | | OK |
metrics are OK
zoom_pan (Begins at: 125 Ends at: 177)
Complexity: | 4 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 53 | | OK |
metrics are OK
zoom_default (Begins at: 180 Ends at: 200)
CalledNBR: | 9 | | OK |
LOC: | 21 | | OK |
metrics are OK
zoom_region (Begins at: 203 Ends at: 229)
Complexity: | 2 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
