[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/i_face.c |3
clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
raster_rgb.c raster_rgb.c Get_location.c com_proto.c
com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c
i_face.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:28 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/i_face.c functions
i_prompt (Begins at: 18 Ends at: 22)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
i_prompt_buttons (Begins at: 26 Ends at: 32)
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 7 | | OK |
metrics are OK
i_coor (Begins at: 36 Ends at: 47)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
i_set_color (Begins at: 50 Ends at: 64)
ParamNBR: | 4 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 15 | | OK |
metrics are OK
i_set_on (Begins at: 67 Ends at: 78)
CalledNBR: | 4 | | OK |
LOC: | 12 | | OK |
metrics are OK
i_update (Begins at: 81 Ends at: 85)
LOC: | 5 | | OK |
metrics are OK
i_new_line_options (Begins at: 88 Ends at: 117)
CalledNBR: | 16 | | OK |
LOC: | 30 | | OK |
metrics are OK
i_set_cat_mode (Begins at: 120 Ends at: 135)
Complexity: | 3 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 16 | | OK |
metrics are OK
i_var_seti (Begins at: 138 Ends at: 148)
LOC: | 11 | | OK |
metrics are OK
i_var_setd (Begins at: 151 Ends at: 161)
LOC: | 11 | | OK |
metrics are OK
i_var_setc (Begins at: 164 Ends at: 177)
CalledNBR: | 6 | | OK |
LOC: | 14 | | OK |
metrics are OK
i_message (Begins at: 180 Ends at: 216)
Complexity: | 7 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 37 | | OK |
metrics are OK
i_add_bgcmd (Begins at: 219 Ends at: 252)
CalledNBR: | 15 | | OK |
LOC: | 34 | | OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
i_var_setd i_var_seti i_prompt_buttons
In vector/v.digit/i_face.c clones of i_var_seti are:
vector/v.digit/i_face.c i_var_setd
In vector/v.digit/i_face.c clones of i_var_setd are:
vector/v.digit/i_face.c i_var_seti
In vector/v.digit/i_face.c clones of i_prompt_buttons are:
lib/gis/env.c G_setenv2
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
