[GRASS-QA] GRASS QA: paul | ./grass6/raster/r.in.gdal/main.c |no clones | 4 monsters | 0 warnings
Thu Mar 1 19:38:39 EST 2007
Hello paul,
ANALYSIS
raster/r.in.gdal/main.c functions
main (Begins at: 40 Ends at: 546)
Complexity:   |      45 |   *** | MONSTER |
CalledNBR:    |     157 |   *** | MONSTER |
LOC:          |     507 |   *** | MONSTER |
3 metric are OUT OF RANGE!
SetupReprojector (Begins at: 552 Ends at: 605)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
ImportBand (Begins at: 612 Ends at: 917)
Complexity:   |      34 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      84 |    ** | Warning |
LOC:          |     306 |   *** | MONSTER |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
