[GRASS-QA] GRASS QA: robertoa |
./grass6/vector/lidar/v.lidar.edgedetection/edgedetection.c
|no clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:39 EST 2007
Hello robertoa,
ANALYSIS
vector/lidar/v.lidar.edgedetection/edgedetection.c functions
edge_detection (Begins at: 11 Ends at: 89)
Complexity: | 7 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 32 | | OK |
LOC: | 79 | | OK |
1 metric are OUT OF RANGE!
Get_Gradient (Begins at: 91 Ends at: 113)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 23 | | OK |
metrics are OK
classification (Begins at: 115 Ends at: 285)
Complexity: | 24 | * | |
ParamNBR: | 16 | *** | MONSTER |
CalledNBR: | 61 | ** | Warning |
LOC: | 171 | * | |
Insert (Begins at: 287 Ends at: 300)
ParamNBR: | 5 | * | |
CalledNBR: | 6 | | OK |
LOC: | 14 | | OK |
metrics are OK
Insert_Interpolation (Begins at: 302 Ends at: 315)
LOC: | 14 | | OK |
metrics are OK
UpDate (Begins at: 318 Ends at: 330)
CalledNBR: | 4 | | OK |
LOC: | 13 | | OK |
metrics are OK
Select (Begins at: 332 Ends at: 374)
Complexity: | 6 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 43 | | OK |
metrics are OK
Create_AuxEdge_Table (Begins at: 377 Ends at: 410)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 34 | | OK |
metrics are OK
Create_Interpolation_Table (Begins at: 412 Ends at: 438)
CalledNBR: | 14 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
