Hello martinl,
ANALYSIS
general/manage/lib/do_rename.c functions
do_rename (Begins at: 11 Ends at: 60)
Complexity: | 8 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 50 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
