[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.out.ascii/main.c
|2 clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
raster_rgb.c raster_rgb.c Get_location.c com_proto.c
com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c
i_face.c main.c main.c level_two.c main.c build.c line.c
read_nat.c areas.c filecompare.c g3dfpxdr.c g3dmisc.c main.c
main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:42 EST 2007
Hello soeren,
ANALYSIS
raster3d/r3.out.ascii/main.c functions
fatalError (Begins at: 53 Ends at: 64)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 12 | | OK |
metrics are OK
setParams (Begins at: 70 Ends at: 110)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 41 | | OK |
metrics are OK
getParams (Begins at: 116 Ends at: 121)
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
writeHeaderString (Begins at: 128 Ends at: 135)
Complexity: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
writeHeaderString2 (Begins at: 139 Ends at: 146)
LOC: | 8 | | OK |
metrics are OK
openAscii (Begins at: 153 Ends at: 184)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 32 | | OK |
metrics are OK
G3dToascii (Begins at: 191 Ends at: 240)
CalledNBR: | 9 | | OK |
LOC: | 50 | | OK |
metrics are OK
main (Begins at: 247 Ends at: 326)
Complexity: | 13 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 80 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
writeHeaderString2 writeHeaderString
In raster3d/r3.out.ascii/main.c clones of writeHeaderString are:
raster3d/r3.out.ascii/main.c writeHeaderString2
In raster3d/r3.out.ascii/main.c clones of writeHeaderString2 are:
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
