[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.to.rast3/main.c |1
clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c
raster_rgb.c raster_rgb.c Get_location.c com_proto.c
com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c
i_face.c main.c main.c level_two.c main.c build.c line.c
read_nat.c areas.c filecompare.c g3dfpxdr.c g3dmisc.c main.c
main.c writeVTKData.c map3.c main.c main.c )| 0 monsters | 0
warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:42 EST 2007
Hello soeren,
ANALYSIS
raster/r.to.rast3/main.c functions
fatal_error (Begins at: 49 Ends at: 68)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 20 | | OK |
metrics are OK
set_params (Begins at: 73 Ends at: 89)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 17 | | OK |
metrics are OK
raster_to_g3d (Begins at: 96 Ends at: 167)
Complexity: | 12 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 72 | | OK |
metrics are OK
main (Begins at: 173 Ends at: 345)
Complexity: | 22 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 55 | * | |
LOC: | 173 | * | |
metrics are OK
open_input_raster_map (Begins at: 352 Ends at: 367)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
close_input_raster_map (Begins at: 372 Ends at: 376)
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.to.rast3/main.c clones of open_input_raster_map are:
raster3d/r3.out.vtk/main.c open_input_map
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
