[GRASS-QA] GRASS QA: martinl | ./grass6/ps/ps.map/ps_vareas.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:35 EST 2007
Hello martinl,
ANALYSIS
ps/ps.map/ps_vareas.c functions
construct_path (Begins at: 13 Ends at: 53)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 41 | | OK |
metrics are OK
plot_area (Begins at: 56 Ends at: 82)
Complexity: | 5 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 27 | | OK |
metrics are OK
PS_vareas_plot (Begins at: 85 Ends at: 195)
Complexity: | 14 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 38 | * | |
LOC: | 111 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
