[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/raster_rgb.c |3
clones ( curses.c graphics.c mouse.c signature.c plot.c
main.c main.c main.c main.c main.c main.c graphics.c
graphics.c graphics.c graphics.c graphics.c c_update.c
d_drop_index.c d_drop_tab.c list.c raster_rgb.c )| 3 monsters
| 4 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:23 EST 2007
Hello glynn,
ANALYSIS
lib/display/raster_rgb.c functions
D_draw_raster_RGB (Begins at: 48 Ends at: 58)
Complexity: | 1 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 1 | | OK |
LOC: | 11 | | OK |
1 metric are OUT OF RANGE!
D_draw_d_raster_RGB (Begins at: 60 Ends at: 69)
ParamNBR: | 7 | ** | Warning |
LOC: | 10 | | OK |
at least 1 values are close to an outlier please consider revising code
D_draw_f_raster_RGB (Begins at: 71 Ends at: 80)
LOC: | 10 | | OK |
D_draw_c_raster_RGB (Begins at: 82 Ends at: 91)
LOC: | 10 | | OK |
D_draw_cell_RGB (Begins at: 93 Ends at: 102)
LOC: | 10 | | OK |
draw_cell_RGB (Begins at: 104 Ends at: 191)
Complexity: | 8 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 88 | | OK |
D_cell_draw_setup_RGB (Begins at: 193 Ends at: 236)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 44 | | OK |
metrics are OK
D_raster_of_type_RGB (Begins at: 238 Ends at: 284)
Complexity: | 2 | | OK |
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 17 | | OK |
LOC: | 47 | | OK |
D_set_colors_RGB (Begins at: 286 Ends at: 295)
ParamNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
D_draw_c_raster_RGB D_draw_f_raster_RGB D_draw_d_raster_RGB
In lib/display/raster_rgb.c clones of D_draw_d_raster_RGB are:
lib/display/raster_rgb.c D_draw_c_raster_RGB
lib/display/raster_rgb.c D_draw_f_raster_RGB
In lib/display/raster_rgb.c clones of D_draw_f_raster_RGB are:
lib/display/raster_rgb.c D_draw_d_raster_RGB
In lib/display/raster_rgb.c clones of D_draw_c_raster_RGB are:
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
