[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.in.v5d/main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:42 EST 2007
Hello soeren,
ANALYSIS
raster3d/r3.in.v5d/main.c functions
fatalError (Begins at: 46 Ends at: 54)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
setParams (Begins at: 65 Ends at: 90)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 26 | | OK |
metrics are OK
getParams (Begins at: 95 Ends at: 104)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 10 | | OK |
metrics are OK
convert (Begins at: 108 Ends at: 181)
Complexity: | 5 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 74 | | OK |
metrics are OK
main (Begins at: 186 Ends at: 228)
ParamNBR: | 2 | | OK |
CalledNBR: | 16 | | OK |
LOC: | 43 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
