[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.kernel/main.c |no clones | 3 monsters | 1 warnings
Thu Mar 1 19:38:33 EST 2007
Hello markus,
ANALYSIS
vector/v.kernel/main.c functions
L (Begins at: 37 Ends at: 61)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
main (Begins at: 64 Ends at: 401)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |     132 |   *** | MONSTER |
LOC:          |     338 |   *** | MONSTER |
2 metric are OUT OF RANGE!
read_points (Begins at: 405 Ends at: 434)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
compute_all_distances (Begins at: 439 Ends at: 463)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
compute_all_net_distances (Begins at: 468 Ends at: 535)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      17 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
compute_net_distance (Begins at: 539 Ends at: 586)
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      10 |       |      OK |
LOC:          |      48 |       |      OK |
1 metric are OUT OF RANGE!
compute_distance (Begins at: 588 Ends at: 634)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
