[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.to.vect/points.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:37 EST 2007
Hello martinl,
ANALYSIS
raster/r.to.vect/points.c functions
extract_points (Begins at: 13 Ends at: 129)
Complexity:   |      23 |     * |         |
CalledNBR:    |      39 |     * |         |
LOC:          |     117 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
