[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.extract/main.c |no
clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:37 EST 2007
Hello martinl,
ANALYSIS
vector/v.extract/main.c functions
add_cat (Begins at: 36 Ends at: 47)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
main (Begins at: 49 Ends at: 363)
Complexity: | 36 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 123 | *** | MONSTER |
LOC: | 315 | *** | MONSTER |
2 metric are OUT OF RANGE!
scan_cats (Begins at: 366 Ends at: 387)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 22 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
