[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/raster.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:23 EST 2007
Hello glynn,
ANALYSIS
lib/display/raster.c functions
D_draw_raster (Begins at: 41 Ends at: 48)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
D_draw_d_raster (Begins at: 50 Ends at: 56)
ParamNBR:     |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
D_draw_f_raster (Begins at: 58 Ends at: 64)
LOC:          |       7 |       |      OK |
metrics are OK
D_draw_c_raster (Begins at: 66 Ends at: 91)
LOC:          |      26 |       |      OK |
metrics are OK
D_draw_cell (Begins at: 93 Ends at: 99)
LOC:          |       7 |       |      OK |
metrics are OK
draw_cell (Begins at: 101 Ends at: 217)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |     117 |     * |         |
metrics are OK
D_cell_draw_setup (Begins at: 219 Ends at: 250)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
