[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_io.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:25 EST 2007
Hello glynn,
ANALYSIS
lib/raster/com_io.c functions
init_transport (Begins at: 161 Ends at: 177)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
R_open_driver (Begins at: 179 Ends at: 183)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
R__open_quiet (Begins at: 185 Ends at: 189)
LOC:          |       5 |       |      OK |
metrics are OK
R_stabilize (Begins at: 191 Ends at: 194)
LOC:          |       4 |       |      OK |
metrics are OK
R_kill_driver (Begins at: 196 Ends at: 199)
LOC:          |       4 |       |      OK |
metrics are OK
R_close_driver (Begins at: 201 Ends at: 204)
LOC:          |       4 |       |      OK |
metrics are OK
R_release_driver (Begins at: 206 Ends at: 209)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
