[GRASS-QA] GRASS QA: martinl |
./grass6/vector/v.transform/setup_trans.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:38 EST 2007
Hello martinl,
ANALYSIS
vector/v.transform/setup_trans.c functions
setup_transform (Begins at: 34 Ends at: 60)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 27 | | OK |
metrics are OK
init_transform_arrays (Begins at: 63 Ends at: 77)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 15 | | OK |
metrics are OK
print_transform_error (Begins at: 81 Ends at: 99)
Complexity: | 5 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
