[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/parse_mon.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:26 EST 2007
Hello glynn,
ANALYSIS
lib/raster/parse_mon.c functions
R_parse_monitorcap (Begins at: 19 Ends at: 103)
Complexity: | 18 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 23 | | OK |
LOC: | 85 | | OK |
metrics are OK
read_line (Begins at: 107 Ends at: 157)
Complexity: | 9 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 51 | | OK |
metrics are OK
substr (Begins at: 162 Ends at: 185)
Complexity: | 5 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 24 | | OK |
metrics are OK
build_path (Begins at: 187 Ends at: 225)
Complexity: | 6 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 39 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
