Hello brad,
ANALYSIS
imagery/i.cca/transform.c functions
transform (Begins at: 10 Ends at: 52)
Complexity: | 6 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 12 | | OK |
LOC: | 43 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
