[GRASS-QA] GRASS QA: glynn |
./grass6/lib/db/dbmi_driver/d_drop_tab.c |1 clones ( curses.c
graphics.c mouse.c signature.c plot.c main.c main.c main.c
main.c main.c main.c graphics.c graphics.c graphics.c
graphics.c graphics.c c_update.c d_drop_index.c d_drop_tab.c
)| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:22 EST 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_driver/d_drop_tab.c functions
db_d_drop_table (Begins at: 12 Ends at: 37)
Complexity: | 5 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 26 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
db_d_drop_table
In lib/db/dbmi_driver/d_drop_tab.c clones of db_d_drop_table are:
lib/db/dbmi_driver/d_drop_index.c db_d_drop_index
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
