[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/base/r3.null.main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:41 EST 2007
Hello soeren,
ANALYSIS
raster3d/base/r3.null.main.c functions
setParams (Begins at: 49 Ends at: 73)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 25 | | OK |
metrics are OK
getParams (Begins at: 78 Ends at: 87)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 10 | | OK |
metrics are OK
modifyNull (Begins at: 92 Ends at: 189)
Complexity: | 13 | | OK |
CalledNBR: | 47 | * | |
LOC: | 98 | | OK |
metrics are OK
main (Begins at: 193 Ends at: 214)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 22 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
