[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/tileio.c |no clones
| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:40 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/tileio.c functions
G3d_getTilePtr (Begins at: 70 Ends at: 112)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 43 | | OK |
metrics are OK
G3d_tileLoad (Begins at: 115 Ends at: 124)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
G3d__removeTile (Begins at: 129 Ends at: 156)
Complexity: | 3 | | OK |
LOC: | 28 | | OK |
metrics are OK
G3d_getFloatRegion (Begins at: 176 Ends at: 208)
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 33 | | OK |
metrics are OK
G3d_getDoubleRegion (Begins at: 211 Ends at: 248)
LOC: | 38 | | OK |
metrics are OK
G3d_getValueRegion (Begins at: 251 Ends at: 260)
ParamNBR: | 6 | * | |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
