[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_get.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Thu Mar  1 19:38:25 EST 2007
Hello glynn,
ANALYSIS
lib/raster/loc_get.c functions
LOC_get_location_with_box (Begins at: 8 Ends at: 10)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |       3 |       |      OK |
metrics are OK
LOC_get_location_with_box_old (Begins at: 12 Ends at: 14)
LOC:          |       3 |       |      OK |
metrics are OK
LOC_get_location_with_line (Begins at: 16 Ends at: 18)
LOC:          |       3 |       |      OK |
metrics are OK
LOC_get_location_with_line_old (Begins at: 20 Ends at: 22)
LOC:          |       3 |       |      OK |
metrics are OK
LOC_get_location_with_pointer (Begins at: 24 Ends at: 26)
ParamNBR:     |       3 |       |      OK |
LOC:          |       3 |       |      OK |
metrics are OK
LOC_get_location_with_pointer_old (Begins at: 28 Ends at: 30)
LOC:          |       3 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
