[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/g3dparam.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:40 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/g3dparam.c functions
G3d_setStandard3dInputParams (Begins at: 41 Ends at: 84)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 44 | | OK |
metrics are OK
G3d_getStandard3dParams (Begins at: 88 Ends at: 155)
Complexity: | 12 | | OK |
ParamNBR: | 12 | *** | MONSTER |
CalledNBR: | 20 | | OK |
LOC: | 68 | | OK |
1 metric are OUT OF RANGE!
G3d_setWindowParams (Begins at: 162 Ends at: 172)
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
G3d_getWindowParams (Begins at: 176 Ends at: 184)
Complexity: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
