[GRASS-QA] GRASS QA: glynn |
./grass6/lib/db/dbmi_client/c_openupdate.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:21 EST 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_client/c_openupdate.c functions
db_open_update_cursor (Begins at: 10 Ends at: 40)
Complexity: | 11 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 21 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
