[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.univar2/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:37 EST 2007
Hello martinl,
ANALYSIS
raster/r.univar2/main.c functions
main (Begins at: 29 Ends at: 339)
Complexity: | 42 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 88 | *** | MONSTER |
LOC: | 311 | *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_int (Begins at: 342 Ends at: 353)
Complexity: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
cmp_float (Begins at: 355 Ends at: 366)
LOC: | 12 | | OK |
metrics are OK
cmp_double (Begins at: 368 Ends at: 379)
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
