[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/tilewrite.c |no
clones | 1 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:40 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/tilewrite.c functions
G3d_tile2xdrTile (Begins at: 13 Ends at: 63)
Complexity: | 10 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 13 | | OK |
LOC: | 51 | | OK |
1 metric are OUT OF RANGE!
G3d_writeTileUncompressed (Begins at: 68 Ends at: 78)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
G3d_writeTileCompressed (Begins at: 83 Ends at: 124)
LOC: | 42 | | OK |
metrics are OK
G3d_writeTile (Begins at: 127 Ends at: 190)
Complexity: | 8 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 64 | | OK |
metrics are OK
G3d_writeTileFloat (Begins at: 193 Ends at: 216)
ParamNBR: | 3 | | OK |
LOC: | 24 | | OK |
metrics are OK
G3d_writeTileDouble (Begins at: 219 Ends at: 252)
LOC: | 34 | | OK |
metrics are OK
G3d_flushTile (Begins at: 255 Ends at: 305)
Complexity: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 51 | | OK |
metrics are OK
G3d_flushTileCube (Begins at: 308 Ends at: 350)
Complexity: | 3 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 4 | | OK |
LOC: | 43 | | OK |
at least 1 values are close to an outlier please consider revising code
G3d_flushTilesInCube (Begins at: 353 Ends at: 436)
Complexity: | 12 | | OK |
LOC: | 84 | | OK |
G3d_putFloat (Begins at: 456 Ends at: 495)
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 40 | | OK |
metrics are OK
G3d_putDouble (Begins at: 498 Ends at: 540)
LOC: | 43 | | OK |
metrics are OK
G3d_putValue (Begins at: 543 Ends at: 559)
ParamNBR: | 6 | * | |
LOC: | 17 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
