[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/g3dfpxdr.c |4 clones
( curses.c graphics.c mouse.c signature.c plot.c main.c
main.c main.c main.c main.c main.c graphics.c graphics.c
graphics.c graphics.c graphics.c c_update.c d_drop_index.c
d_drop_tab.c list.c raster_rgb.c raster_rgb.c raster_rgb.c
raster_rgb.c Get_location.c com_proto.c com_proto.c
com_proto.c loc_proto.c loc_proto.c loc_proto.c i_face.c
main.c main.c level_two.c main.c build.c line.c read_nat.c
areas.c filecompare.c g3dfpxdr.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 1 19:38:39 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/g3dfpxdr.c functions
G3d_isXdrNullNum (Begins at: 21 Ends at: 35)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 15 | | OK |
metrics are OK
G3d_isXdrNullFloat (Begins at: 40 Ends at: 44)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
G3d_isXdrNullDouble (Begins at: 49 Ends at: 53)
LOC: | 5 | | OK |
metrics are OK
G3d_setXdrNullNum (Begins at: 58 Ends at: 72)
Complexity: | 2 | | OK |
LOC: | 15 | | OK |
metrics are OK
G3d_setXdrNullDouble (Begins at: 77 Ends at: 81)
LOC: | 5 | | OK |
metrics are OK
G3d_setXdrNullFloat (Begins at: 86 Ends at: 90)
LOC: | 5 | | OK |
metrics are OK
G3d_initFpXdr (Begins at: 97 Ends at: 142)
Complexity: | 6 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 46 | | OK |
metrics are OK
G3d_initCopyToXdr (Begins at: 153 Ends at: 176)
Complexity: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 24 | | OK |
metrics are OK
G3d_copyToXdr (Begins at: 181 Ends at: 224)
Complexity: | 8 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 44 | | OK |
metrics are OK
G3d_initCopyFromXdr (Begins at: 229 Ends at: 252)
LOC: | 24 | | OK |
metrics are OK
G3d_copyFromXdr (Begins at: 257 Ends at: 300)
LOC: | 44 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
G3d_copyFromXdr G3d_copyToXdr G3d_initCopyFromXdr G3d_initCopyToXdr
In lib/g3d/g3dfpxdr.c clones of G3d_copyToXdr are:
lib/g3d/g3dfpxdr.c G3d_copyFromXdr
In lib/g3d/g3dfpxdr.c clones of G3d_initCopyToXdr are:
lib/g3d/g3dfpxdr.c G3d_initCopyFromXdr
In lib/g3d/g3dfpxdr.c clones of G3d_copyFromXdr are:
lib/g3d/g3dfpxdr.c G3d_copyToXdr
In lib/g3d/g3dfpxdr.c clones of G3d_initCopyFromXdr are:
lib/g3d/g3dfpxdr.c G3d_initCopyToXdr
Threshold GRASS6 key metrics values at 2007-03-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
