[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.his.rgb/closefiles.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Mar 2 06:39:13 EST 2007
Hello brad,
ANALYSIS
imagery/i.his.rgb/closefiles.c functions
closefiles (Begins at: 9 Ends at: 28)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 20 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
