[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.his.rgb/his2rgb.c |no clones | 0 monsters | 1 warnings
Sat Mar 3 19:16:15 EST 2007
Hello brad,
ANALYSIS
imagery/i.his.rgb/his2rgb.c functions
his2rgb (Begins at: 22 Ends at: 139)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |       0 |       |      OK |
LOC:          |     118 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
