[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.random/count.c |2
clones ( count.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 3 19:52:23 EST 2007
Hello brad,
ANALYSIS
raster/r.random/count.c functions
get_stats (Begins at: 15 Ends at: 88)
Complexity: | 12 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 74 | | OK |
metrics are OK
set_min (Begins at: 91 Ends at: 119)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 29 | | OK |
metrics are OK
set_max (Begins at: 122 Ends at: 150)
LOC: | 29 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
set_max set_min
In raster/r.random/count.c clones of set_max are:
raster/r.random/count.c set_min
In raster/r.random/count.c clones of set_min are:
raster/r.random/count.c set_max
Threshold GRASS6 key metrics values at 2007-03-03 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
